How to determine Reactive black 5 dye
Could anyone tell me how to analysis Reactive black 5 dye (component after cleavage like azo group, aromatic structure) using HPLC DAD Shimadzu and with C18 column?
Thanks.
You have found this site, so you have both a computer and an Internet connection.
As a first step, how about a literature search ?????????
Feel free to look this up:
BS EN 14362-2:2003
Textiles. Methods for the determination of certain aromatic amines deriv ed from azo colorants. Detection of the use of certain azo colorants accessible by extracting t he fibres
Status : Superseded, Withdrawn Published : November 2003 Replaced By : BS EN 14362-1:2012
http://shop.bsigroup.com/ProductDetail/ ... 0030147644
Please, see what you think and thank you.
MattM
It is very easy to determine Reactive black 5 dye content using HPLC DAD Shimadzu with C18 column. All you need to do it is have:
- a HPLC Shimadzu with DAD detector
- a validated method to determine Reactive black 5 dye content
- appropriate C18 column
- standard of Reactive black 5 dye
- sample you want to analys
First thing you need to do is purge and clean you HPLC. Then put your C18 column in to the HPLC system. Make a standard solution and a sample solution. Run those solution with validated method to determine content of Reactive black 5 dye. Make appropriate calculation. And buum! There you go! Hope I helped. :)
Users browsing this forum: Bing [Bot], Semrush [Bot] and 15 guests
