RP-LC/MS Standard
Hello all,
I'm running Ammonium acetate/Acetonitrile gradients on 75 um C18 columns that I pack. I spray specifically in negative mode for nucleic acids so I'd like to have something larger in the mix.
I was hoping someone had some suggestions of what compounds I could use as the typical RP standards are not ideal for negative mode. ( Uracil, caffeine, etc)
Much obliged!
Johte,
I regularly use the antibiotic Chloramphenicol to evaluate LC/MS systems in negative ESI mode.
Users browsing this forum: Google [Bot] and 11 guests
