Methods for pegylated separations
I've been working with pegylated (5 and 10kD) peptides (4-6kD) on a C18 column, and it appears that the unreacted PEG and pegylated products are eluting together late in the run.
Because typical reversed phase (C18 column, acetonitrile/water, 0.1% TFA) has worked so nicely for the peptides (eluting at 2-5 column volumes with a gradient) I was hoping to work with that method for the products as well. Are there conditions I should try with RPLC, or is there another known method for pegylated products that allows sharper resolution (I was thinking either size exclusion or hydrophobic interaction)?
Typical run:
Vydac C18 250 x 4.6 mm column
A = 0.1% TFA in water
B = 0.1% TFA in acetonitrile
10 - 50% B over 30 minutes, 1 mL/min, ambient temp.
Peptides elute at 20-25% B, product (I think) around 40%.
Any suggestions would be appreciated!
Boaz Vilozny
PEG is rather hydrophobic. It's not retained on a HILIC column until you get close to 90% ACN. Why not separate your PEGylated peptides from unreacted PEG using a HILIC SPE cartridge? At ~ 75-80% ACN your PEGylated peptides will be retained (the HILIC material will look at the peptide portion and ignore the PEG chain) while the unreacted PEG will elute in the filtrate. A step to an aqueous medium will then elute the peptide.
I do recommend using a SPE-HILIC material with a pore diameter of at least 300 Å. A material with a pore diameter of 100 Å will be too retentive of peptides this large, even if steric hindrance isn't a concern.
PolyLC Inc.
(410) 992-5400
aalpert@polylc.com
Thanks Andy - that's a great suggestion. By the way, I've got some columns from PolyLC, and I'll be sure to check you guys out for SPE materials as well.
Boaz
In total there are 15 users online :: 2 registered, 0 hidden and 13 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], Semrush [Bot] and 13 guests
