Why do almost no CE methods use an internal Standard
Discussions about CE, MEKC and related topics
Why do so few CE methods use an ITSD? I've read quite a few and see almost none. I would think with the variability of how much material gets injected it would be very beneficial.
I don't know, but i always try use an internal standard when developing a method. In CE is easy to have variations in injected volume (due to the low volume injected correlated with viscosity and superficial tension difference) and migration time due to almost omnipresent EOF.
Users browsing this forum: Semrush [Bot] and 1 guest
