Running CSH column with 100% aqueous?
Can we run a Waters C18 CSH column with a 100% aqueous mobile phase without having any problem?
If not, what should be the minimum methanol or acetonitrile % in the mobile phase?
Thanks in advance.
AFAIK, should be Ok with 100% water.
Unless your samples and standards are in 100% water you're not buying yourself anything with 100% mobile phase. I'd tend to run at least 5% organic phase and worry a lot more about the final solvent system of the sample.
Mark Krause
Laboratory Director
Krause Analytical
Austin, TX USA
Users browsing this forum: Bing [Bot], Semrush [Bot] and 9 guests
