Scaling Chromatography in Chemstation (GC - b.01.03)
I want to adjust the scale of the chromatogram on the printed report. I haven't used chemstation in YEARS so I'm basically back to square 1 as far as trying to even get the simplest tasks completed. I can manipulate the chromatogram in data analysis mode fine, but I can't figure out how to change the scaling on the final report. The analyte peak I'm trying to scale to is tiny compared to the solvent peak, and it autoscales to the solvent peak. Help?
Report --> specify report --> Signal Options
Manually set the time range and output range in Data Analysis (under Graphics), and re-save the method.
