polymeric reversed phase columns
8 posts Page 1 of 1
Hello!
Does anyone out there know a manufacturer of polymeric reversed phase columns (non-silica packing material). 0.3 mm ID??
thanks for your help,
regards Bert
Hi Bert,
You can found info about this kind of columns in:
http://www.polymerlabs.com/hplc/pharmacopeia.htm
Cheers
Alejandro
Applications Chemist in Mass Spectrometric
Supelco used to make a column like this. Have not checked on it recently.
I suspect the problem is less the "polymeric" than the "0.3 mm". I don't know of anyone who packs polymeric materials in that size column. You might check LC Packings (Dionex) for monolithic polymeric columns in that size range:
http://www1.dionex.com/en-us/columns_ac ... s5327.html
Thanks for your help! I found what I needed :D
Regards Bert
Okay, now share with the rest of us! 8)
Tom, lets share:
as Alejandro suggested, I contacted polymer labs and found exactly the column I wanted. I want to try this column for the teracycline analysis with the keto-enol tautomerism problem (previous thread). The idea is to use relative high salt concentrations in the mobile phase. I would like to see if excessive contamination of the source can be prevented due to the low flow I can use with the 300 µm column ...... :roll:
Regards Bert
Thanks, Bert!
8 posts Page 1 of 1
