Backup
Hello guys. You as managed backup raw data software no longer in use ? given that without the software is unable to open the data .
Thks
The manufacturer usually provides an export function to eg NetCDF.
or use a Data file converter, and save it in a non proprietary format that is currently supported.
mzXML, uses more disk space, but can be read in notepad.
http://www.sisweb.com/software/masstransit.htm
http://www.sisweb.com/software/csw/gcmsfile.htm
When I was working, our pointy-haired boss spent THOUSANDS of dollars to have such old data converted to a newer format (which apparently was only partially successful) and then updated our instruments and software to OpenLab which cost us hundreds of thousands of dollars.
Of course: our results were no more accurate with the new systems and software...
I never was a big fan of Dilbert, then I graduated and got a job . . .
Yep, I deeply understand your frustration. Among other reasons, that was why I started the OpenChrom project:
https://openchrom.net/download
https://en.wikipedia.org/wiki/OpenChrom
It hopefully helps you to convert your data files.
https://wiki.openchrom.net/index.php/Op ... data_files
Thank you very much "eselmeister". your links are too Useful & helpful.
Florence Fiona
Every time we retire and old instrument with obsolete software, I try to keep the PC in storage just in case I have to bring back the old data. We have the data backed up on a file server and tapes, but sometimes you just can't make old software work on new operating systems so if I can keep at least one copy on an archived PC that helps a lot.
Once our 5 year data retention period has expired I can then dispose of the old PC.
In total there are 30 users online :: 0 registered, 0 hidden and 30 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 30 guests
