HPLC - Pressure climbing
I am using a RP-C18 column by phenomenex. The solvents I am using are 70% Methanol and 30% Water.
For some reason when I inject even the lowest concentration of a vitamin E like substance i.e. 1ppm of a vitamin E like substance in methanol the pressure continues to climb up to 3500.
Is there anything you can suggest to prevent it?
Many thanks
Dear Theresa:
Is the pressure climb momentaneous or continuous?
What is the particle size?
Are you using a guard column?
In addtion to Rafael questions, at what flow rate are you running?And check if there is any leakage.
Users browsing this forum: Bing [Bot], Semrush [Bot] and 4 guests
