Back again with N-methylpyrrolidone in API
Hi all !!!..
A new year has come but troubles have not changed.
Is ther anyone who has a method to control absence of N-Methylpyrrolidone in API's. USP and EP claim taht HS/GC is not an enought sensible technic.
Any help will be appreciated.
Thanks and have a nice year !!!!!
Basil
If you can document that your procedure does meet the requirements and meets the guidelines for a validated procedure, just document it. There are updated ways to do lots of assays, and to push them through EP or USP takes time and money; lots of EP and USP procedures are long-outdated or awkward.
Hello!
We have two GC methods (it is possible also HPLC-see questions in HPLC section-we have got the answer there):
1. Column AT5 (30m x 0,53mmID x 5mcm)
FID
carrier gas: He 4ml/min
Split 1:5
Oven T:40stC (6min)-10stC/min- 150stC(5min)-3stC/min- 165stC (10min)
T inject:220stC
T det:250stC
Solvent.DMSO
We determine also other solvents so Run is long. NMP elutes after the solvent peak (RT cca 21min)
2. Column CP-SIL 5 (30m x 0,53mmID x 5mcm)
FID
carrier gas: He 5ml/min
Split 1:5
Oven T:150stC
T inject:120stC
T det:250stC
Solvent: Ether
NMP elutes after the solvent peak (RT cca 7,6min)
I hope it will help you somehow. Bye!
ana
2.
juju
If it's applicable, HPLC methodology was referenced in this thread
Thanks juju (or ana) :lol:
We will try with your first option.
I hope we would have enought sensibility with this method (if nout I'd chandge split ratio).
I'll tell you how it works in our lab
Thanks again
Basil
Users browsing this forum: Bing [Bot], Google [Bot] and 9 guests
