HPLC with DMSO as solvent
Posted: Fri Jan 20, 2006 1:20 am
Is it possible to use HPLC to analyze the concentration of small molecules dissolved in DMSO? If not, is there a suitable method?
Chromatography Forum is a public discussion group where you can post questions, news, or messages of interest to chromatographers everywhere, but you must be registered to participate (registration is FREE). If you are a registered user, please log in.
http://chromforum.org/
DMSO is used as surfactant to solubilise sample in HPLC. Being a strong solvent should be used in less amount.Is it possible to use HPLC to analyze the concentration of small molecules dissolved in DMSO? If not, is there a suitable method?
Was it with Normal-phase or Reversed-phase mode?We have used DMSO (water-free) as diluent for a substance that very sensitive to water. The sample is injected in less than 20 uL and found no significant peak distortion.
