Syst Suit as Method User Program addon in Totalchrom
Has anyone out there done this? I'd like to automate the sys. suit. tests a bit more so that I can get tailing factors, etc., on regular reports and summaries. I apparently am not getting the syntax right on the command line. Manual is a little vague here.
Thought I remembered someone posting instructions to do this on this forum, but I couldn't find that post.
All standard disclaimers apply: This post reflects personal opinion only and not the policies of my employer.
Hi Mary,
I had to play around a bit! Select the suitability (suit.exe) program file in the first line of "User programs" tab (when in method>process>user programs.It should display the suit.exe file extension in the box next to the radio button.
I had:
$RSTspacee:\turbochrommethods\fingerprint.suispace/1spaceprn<epsonspacestylusspacecolorspace850>
I have typed space for one space between letters/numerals
where e:\turbochrommethods\fingerprint.sui was the file and epson stylus color 850 was my printer - you may have to use exact upper and lower case on the printer name.
I found the program didn't work unless I had the exact syntax - so keep trying and experiment.
Please post if it works or not
WK
Haven't found the right syntax to make it work yet. Fly in the ointment seems to be that we're actually running Totalchrom Small Client Server version--filenames with pathnames need to be in quotes (maybe), and using the right naming convention. PE tech support is helping with this. Maybe we'll have it figured out by tomorrow.
Users browsing this forum: Bing [Bot] and 2 guests
