Calibrating, area vs. height
Discussions about IC and related topics
Which is typically used for calibrating/analysis, height or area? Is it wrong to use one over the other?
Thanks.
For tuning purposes use the hight.
For STD calibration and samples area
What are you referring to when you say tuning? Are you referring to the check standards?
Thanks.
