Integrate Nystatin Peaks
Hi all,
I can't separate all antibiotics peaks nicely. I wonder if no-valley-to-valley integration allowed.
Also, do topical drugs need degradants to be monitored? Is reporting threshold set same as oral drugs?
Thank you.
Is this a USP procedure ? In general, the way I understand it is that anything that you can validate and document is acceptable. If USP procedures were all "perfect", I wouldn't be as bald as a doorknob these days !!!
The way I understand this is that the regulations are the same; hopefully current thinking is different. In my own mind topical leave-on and wash-off products should also be considered different...
In total there are 20 users online :: 2 registered, 0 hidden and 18 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], Semrush [Bot] and 18 guests
