Sodium Perchlorate in Mobile Phase
I am looking at the Pharmacopoeia methods for the analysis of Tylosin and they all contain Sodium Perchlorate in the mobile phase (aqueous solution with Acetonitrile at pH 2.5). Due to the risks associated with this material I would like to swap it for something else. What role does the Sodium Perchlorate play in mobile phases, is it simply a buffer that can be exchanged for something else?
Perchlorate is an ion-pairing agent, about as strong as trifluoroacetate. NaClO4 is a neutral salt that does not buffer. Its main virtue is UV transparency. You can try a short-chain sodium alkanesulfonate as a substitute.
Mark Tracy
Senior Chemist
Dionex Corp.
In total there are 19 users online :: 2 registered, 0 hidden and 17 guests (based on users active over the past 5 minutes)
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 17 guests
