ACIDS LIKE TARTARIC ACID ETC.
Dear Friends,
When I developing methods for salts like fumerate, tartrate, maleate of some drugs, I am getting problem of these salts. They elute at below 2 min and getting merged with blank . To avoid this blank intereference is very difficult. Whatever mobile phase and whatever column may be , the problem is persisted. :? Can anybody suggested a solution
raman
Can anybody sugest a isomer separation method for pramipexole
Hi Raman,
I don't know if it could be helpful to you but everytime I analyse such compounds I use the ionic chromatograph... it works!
google.
Excel
Thank you Zompa
But in our case, while analysing the drug this salt will also respond at a lower level. So we are asked to address and quantify the same at this level. That is the reason we are struggling.
Raman
I assume that you have developed methods already for content uniformity, impurity profile and degradation products of the parent drug. If this is the case, the simplest method is to develop a separate method for the counterions, maybe with ion-pair chromatography or ion chromatography, and then use this method as a generic method for the counterions.
Is this acceptable?
Ok,
What Uwe suggested is what we do ordinarily when we analise such drugs.
We have separate methods for the counter-ions and for the "base".
So we "off-integrate" the peak of the anion while testing the counterpart purity.
bye.
