Sulphamic acid on LCMS..
Posted: Sun Mar 19, 2006 10:47 am
Hi everybody,
We have to transfer a method from LC-UV to LCMS (ESI). In the original method there is sulphamic acid and NaOH in the mobile phase (pH2) and a silica column, C18.
My question is about the use of sulphamic acid and NaOH with the detector MS.. I think we need to change them with TFA to get the same pH and similar elution.
What do you think about this?
Thanks in advance for the help,
Have a good day!,
Davide
Have a good day!,
Davide
