Varian 3400 error code.
Hello. I have some trouble with my unit Varian 3400cx. It's display "Fault 13" and " Fault 37". I don't have manual for my unit. Anybody can tell my what this is errors about? Thanks.
I'm at home now. I will look the manual next monday
Next monday I will have a look yo the manual.
Regards
I can send You the manual in pdf (4,3MB) via email.
13 Power fail occurred (latched)
AC power to the instrument was interrupted, either by a power failure or by turning off the main power switch
37 Power line ground fault (latched)
The polarization of the power line connection is reversed, or the ground connection through the power cord is missing. Normal chromatographic functions are not affected, but the risk of electrical shock is increased for certain maintenance operations and in case of some component failures.
So, first just try to turn 180 the main power plug.
Please can you send me (patsay@mail.ru) the manual for Varian 3400 ?
