Thin Layer Chromatography
Hi!!
A simple TLC can be considered a qualitative or semi-quantitative analysis?
Like this for example:
Without knowing details of what I'm supposed to be looking at, it's difficult to be specific. But, in general:
  • TLC is widely used as a qualitative technique (do a Google on the keywords tlc + pharmacognosy for examples).
  • TLC can be quantitative, but that gets cumbersome, usually requiring densitometry. That was a semi-hot area when I started doing chromatography in the mid-70s, but has been almost completely eclipsed by HPLC today.
  • I'm not sure what you mean by "semi-quantitative". You can run your sample on a plate bracketed by varying-level samples and do a visual comparison, but that gets *very* subjective and it gives away one of the advantages of TLC: the ability to process multiple samples in parallel.
In total there are 17 users online :: 1 registered, 0 hidden and 16 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot] and 16 guests
