SGE HT8 column for PAH's
Posted: Wed Dec 07, 2016 12:42 pm
Hi
In the near future the reglementation (In Belgium) for the analysis of PCB's in drinking water will change and we'll have to be able to seperate PCB 28/31
We now use a Rxi5 silMS 30-0.25-0.25
To avoid working on two different systems and having to reinject positive samples on a different column, we would like to try and analyse PAH and PCB's in one run on a column that can seperate PCB 28/31
We are using a Triplus RSH to do an automated liq-liq extraction with 50/50 pentane/DCM followed by 50µl large volume injection.
Will a SGE HT8 column work for this application and deliver good separation for both PCB 28/31 and for benzo(b)-benzo(k)-fluoranthene (we don't need to separate benzo(j) ?
are there other columns that might work better?
thanks a lot for your input
BMU
BMU
