5890 Series II Instruction Manual
Hello all,
I have a simple question. We have a 5890 Series II GC at my work, and I need to change out our column. Unfortunately, the instruction manual was lost long ago (before I ever started here) so I don't quite know the adjustments (ie how much the column should protrude from the ferrule, etc). Does anyone know where I could get an instruction manual?
Or even better, give me the basic necessities for installing a megabore (DB-1) column?
I appreciate your help!
-Robin
I'd go with 4 mm column protruding at the inlet end; at the detector end, push the column up until it hits the FID (a few inches), then pull back 1 or 2 mm and tighten. Agilent has a video showing column installation http://www.chem.agilent.com/cag/cabu/howtovideo.htm and check out http://www.chem.agilent.com/cpdocs/a158 ... N=99646943
Agilent has a good tech support online
In total there are 14 users online :: 0 registered, 0 hidden and 14 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 14 guests
