Shimadzu CBM-20A reset and IP address
I'm installing a Shimadzu CBM-20A into Chromeleon using the network connection. The 20A has been in storage for months if not years. Does anyone know how to reset the system and what the default IP address is? 192.168.200.??
Thanks!
To find the default ip address, you might be able to connect it to a LAN and then use an ip scanner program (e.g., http://www.advanced-ip-scanner.com ) to find it.
In total there are 15 users online :: 2 registered, 0 hidden and 13 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], Semrush [Bot] and 13 guests
