CP-4900 best newer version software
Hi! we currently own a Varian CP-4900 and we use Star as our software and Natural Gas Report to generate reports, we only take Natural gas C6+ samples, our current report doesn't show un-normalized values and our new customer requires it, What would be our best option? Since as we understand Star is not supported any more.
Thanks in advance!
you can use either OpenLAB 2 or OpenLAB EZChrom for that. OpenLAB 2 has a RGA/NGA plug-in for free.
Freek Varossieau
OpenLab CDS 2 specialist
BeyondOpenLab
beyondopenlab@gmail.com
+5977114721
Hmmm Intuvo 9000 Series i see. Will look into it...
Intuvo 9000 is a very nice machine but not a compact GC like the 4900.
On the bench space of a 7890 you can almost fit 2 9000 :)
Controlling the Intuvo 9000 with OpenLAB 2 was a breeze :).
Freek Varossieau
BeyondOpenLab
+5977114721
A technical question:
Is the Intuvo 9000 has the same device model from the software point of view (Fixed and Variable configuration) and controlled via the same Rapid driver as 7890 via XML-RPC calls?
Yep both use the RC.Net drivers.
Freek Varossieau
BeyondOpenLab
+5977114721
In total there are 21 users online :: 0 registered, 0 hidden and 21 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 21 guests
