Abbreviation standardization consensus
Our internal powers-that-be have declared that all our in-house documents should use the same abbreviation for liquid chromatography tandem mass spectrometry. We have noticed a lack of consensus in the literature. IUPAC seems to be heading firmly toward "MS/MS" (rather than "MS-MS") but seems silent or ambiguous about what connects the chromatography to the mass spectrometry. They list both "GC/MS" and "LCMS" in the appendix of the current (March 2006) draft (http://www.msterms.com/docs/IUPAC_MS_Te ... _Draft.pdf). :?
So, my question to the readers of this forum: Is there a hyphen in the abbreviation of hyphenated techniques?
All standard disclaimers apply: This post reflects personal opinion only and not the policies of my employer.
If such an important question arises, it is in my experience best to sit back and wait until the question resolves itself. :D
I believe John Langley from the BMSS was putting together a list of such abbreviations for IUPAC. He passed them around for discussion/comment a while back. I cant recall if they have been published as yet. You could try contacting John via the BMSS website.
That would be the document I quoted above that lists both "GC/MS" and "LCMS"...
Even though I'm still a grad student so what I say doesn't yet count for anything, my opinion is to hyphenate, since they are after all hyphenated techniques. Also a separation between the chromatography and the detector is necessary. If they were the same procedure, then write it out as LCMS, but as they are not, there should be a distinction between the two.
But as I said, my opinion doesn't count yet, so I'll just wait and see what IUPAC concludes
RJP
Montreal, QC, Canada
