TCD fuse 1.0A use, if using for 1.6A fuse, that it is fine?
Posted: Thu Jan 26, 2017 1:50 am
Gas chromatography detector, TCD recomend use for 1.0A fuse, but i for useing 1.6A fuse do not it is fine?
Chromatography Forum is a public discussion group where you can post questions, news, or messages of interest to chromatographers everywhere, but you must be registered to participate (registration is FREE). If you are a registered user, please log in.
http://chromforum.org/
thanks for answer.Fuses are cheap. I would only risk using a higher amperage fuse as a temporary measure until I could get the correct one.
