serum vials for gas sample collection and analysis
I need to collect small amts of gas samples from a reactor and analyze them in a Shimadzu GC-FID. I have used tedlar gas sampling bags in the past, but they are simply too big; I am looking at sample volumes of ~1-10 cc per analysis.
I have come across gas sampling serum vials (used primarily in microbiology and biogeochemistry) to collect small amts of gases. This link is one of many :?
http://rydberg.biology.colostate.edu/~j ... _vials.htm
Does anyone in this forum have experience in doing this kind of stuff ? what is the quality of serum vials (and septa) that can be used for this purpose ? Is a normal vacuum pump ok ?
Pradeep
Hi Pradeep
I would advise againbst using serum vials - the septa are not designed for GC work, and will bleed volatiles into your samples.
Rather use GC headspace vials - these also have septum caps but they are designed for GC and will have low bleed.
hi Peter,
Thank you very much for the suggestion. Could you kindly also tell me if this could be used to analyze just gases ? (i.e., my samples are gaseous & so i dont have a liquid phase.) can i evacuate the vial too ? lastly, can i inject gases into a evacuated head space vial without appreciable bleed?
thanks,
pradeep
Hi Pradeep
Hi Pradeep
If you only want to analyse gasses i.e. carbon dioxide, oxygen, hydrogen etc etc than a serum vial will probably be OK - the septum will bleed organic volatiles that might not interfere with the gas analysis.
A GC headspace vial is very similar to a serum vial, and has the same crimp cap with rubber septum, but the rubber is designed to tolerate higher temperatures. What you can do with a serum vial in terms of evacuation and filling you will be able to do with a headspace vial.
If you already have serum vials, try them first before you spend money on headsapce vials.
Regards Peter
