Phenylephrine separation with stabalizers
Posted: Fri Feb 10, 2017 1:05 pm
by ChromChem
I have a method to analyze Phenylepthrine using HPLC based of the method here:
http://www.phenomenex.com/Application/Detail/3246
The only difference is I'm using a slightly lower flow rate at 0.7mL/min
It works wonderfully for Phenylephrine by itself,but now I am trying to analyze a solution with Phenelyephrine HCl, sodium chloride, sodium bisulfite, and edetate disodium and I have two peaks that are very close to each other.
Any tips on how to get these two peaks to separate better without drastically changing the method? I've already tried altering the flow rate and temperature...
Thanks!
Re: Phenylephrine separation with stabalizers
Posted: Fri Feb 10, 2017 1:47 pm
by HPLC chemist
Use a 5 cm Luna column. Eliminate Octanesulfonic Acid (its obsolete) and replace it with 0.05 M Phosphate buffer pH 3.0. Go gradient to tease these peaks apart.
Posted: Fri Feb 10, 2017 1:49 pm
by HPLC chemist
Its apparent this Phenomenex method does not work for your sample matrix.
Posted: Wed Feb 22, 2017 1:30 am
by ChromChem
Thanks for the reply! I have replaced the Octanesulfonic Acid with acetic acid (pH 3.0) do you think the buffer is necessary to desperate or will the gradient surfice?
Posted: Wed Feb 22, 2017 3:19 am
by HPLC chemist
Gradient. We could only separate Acetaminophen, Phenylephrine, Doxylamine HBr, Diphenhydramine, and Chlorpheniramine HCl using gradient and wavelength shifting.
Posted: Tue Feb 28, 2017 3:21 am
by ChromChem
Would you mind sharing a method?
