DAD vs. DWD S/N-difference [August 13, 2004]
By Confused? on Friday, August 13, 2004 - 04:49 am:
Hey all!
What do you think about a signal to noise ratio (and sensitivity) difference between two detectors, namely DAD (agilent) and DWD (Waters)? DAD gave about 40 times smaller S/N-ratio than DWD. Is it possible even in theory or should we look a reason for this from somewhere else?
diode-array detectors are probably somewhat less sensitive than variable-wavelength, but 40X seems a bit much. Are you sure you're running both detectors under equivalent conditions (bandpass, time constant, etc.)?
Users browsing this forum: Bing [Bot], Semrush [Bot] and 10 guests
