gradient elution waste composition calculator
Hi all
Just wondering if anyone has come across, or even perhaps written a program, that allows for the input of your HPLC gradient conditions and then generate a % waste for each reservoir on (say) a per litre basis.
The output im thinking of would be along the lines of:
82% ResA
16% ResB
2% ResC
For most gradients this calulation can be done pretty easily manually, but if we can do it via software...then why not. Would make the labelling of HPLC generated waste a little more easier to do.
Havagoodweekend!!
Peggsy
Why not just stick the calculation in a spreadsheet? If you want to share it, e-mail me privately and we can look at setting up a repository for shared tools of this kind.
Hi Tom
I'll give it a go then mate, was being lazy i suppose and seeing if this was already created somewhere in the "webosphere". (why reinvent the wheel?)
Cheers
Peggsy
Sometimes, because the original inventor assumed that pi ≈ 3, and the resulting hexagonal wheels roll with a pronounced "thump". :lol:
That sounds like a feature that could be built into the instrument control system. Many systems track solvent consumption, why not waste generation? I'll ask someone at Softron.
Mark Tracy
Senior Chemist
Dionex Corp.
Users browsing this forum: Ahrefs [Bot], Semrush [Bot] and 3 guests
