What is this curious instrument?
Off-topic conversations and chit-chat.
We were cleaning up in the deepest depths of the farthest laboratory warehouse, and we found this instrument.
No one has an idea what it is or what is it used for.
Of course, a few guesses have come up, most likely some physical analysis like maybe some sort of density? Vapor pressure? but no one knows for sure.
Maybe some of you wise old ones can shed light on the subject.
http://i.imgur.com/roEDXwP.jpg
EDIT:
I have a good guess on why we can't easily guess the nature of this instrument, the scale has no units! :cry:
We had (and used) one of these
I have absolutely no idea about the original-poster's instrument, but if we're in the realm of random guesses in the hopes that someone eventually comes up with the right answer, and the rest of us are allowed to look silly for wildly wrong guesses, this is my wildly-wrong guess: device for measuring permeability of membranes to liquids.
lmh may be very close - Googling the company name gets this book https://books.google.co.za/books?id=JdH ... td&f=false
which lists them as having a patent that is something to do with water vapour permeability.
It also gets a cutaway motorcycle engine display https://new.liveauctioneers.com/item/42693936 with a certain stylistic resemblance to the mystery instrument, and quite a few references to various bits of lab equipment.
Here: I made his picture visible.
Never used one but I think I know. The glass cylinder in the middle contained concentrate sulfuric acid. It had a 2 hole rubber stopper where 1 end was attached to a steam distillation unit. The distillate was bubbled through the acid and dewatered.
The other hole was attached to the device on the right which collected a dewatered oil that was weighed by the scale (measuring scale on right).
Thus, the analyst knows the volume he distilled and the amount of oil he collected. It was a 1930-1950's technique.
This is a Chittick Apparatus, used to measure the volume of CO2 gas evolved from a sample, and then compared to the CO2 evolved from a sodium bicarbonate or sodium carbonate standard to determine the carbonate content of the sample. Sulfuric acid is delivered from the small buret to acidify the carbonate/bicarbonate.
Acid/water plus methyl orange dye goes in the right-hand side.
