Agilent GC 450 no flow no heat
Posted: Mon Mar 27, 2017 1:36 pm
We have an Agilent GC 450 with a FID and MS detector. A couple weeks ago, we experienced a blockage in the split vent line of the FID injector. After we remove the block and put everything back together, the GC would not respond to any commend. It would not heat up nor have any flow through the system. Upon starting the front panel still lights up and goes through the starting process. Then the whole system would park at 50˚C (injector, detector and oven) with no flow. If we manually change the temperature on the front panel of the GC, it does not response. Has anyone had this problem before or known what is happening? Thanks.
