SIM METHOD
Pls. any one can help me in developing SVOC analysis by SIM method
You can adapt this. I don't see any atoms in common (except Carbon) so I doubt you can remake the wheel and develop a SIM method.
https://www.thermofisher.com/ca/en/home ... lysis.html
Look at EPA 525.3.
I made a SIM method for the full Appendix 9 VOC list, just used the normal quant ions and qualifier ions from a full scan method, then divided them up into time segments to try and keep it to about 15-17 ions per segment with 10ms dwell times. Use a full scan run to find retention times, then adjust the starting points for each segment from that using the same temperature program. It takes time but it isn't too difficult.
Users browsing this forum: DuckDuckGo [Bot] and 10 guests
