the union between transfer line of G1888 and GC6890
I want to connect the transfer line of G1888 to the carrier gas tubing of injection port of G6890. But the union I have isn't correct. I guess the nut of carrier gas tubing from injection port is 1/16 inch. But the end of transfer line is a metric male nut. Could anybody tell me where I can buy the zero dead volume union with two different female connectors? And the part number too. Thanks
The machine is Agilent G1888 and GC6890
Hello
It is easier to cut tip of HS transfer line and install 1/16 nut.
Just remember to connect transfer line very close to GC inlet to avoid "cold spot".
Regards
Tomasz Kubowicz
Regards
Tomasz Kubowicz
Agilent has a part number to enable the M5 nut on the HSS transfer line to connect to 1/16 tubing. Part number is G3521-80000
Gasman
Gasman
In total there are 24 users online :: 3 registered, 0 hidden and 21 guests (based on users active over the past 5 minutes)
Users browsing this forum: Amazon [Bot], Bing [Bot], Semrush [Bot] and 21 guests
