Two in progress status when running GC Agilent
Hi all,
Please help me out, I am running GC Agilent using Chemstation sofware with 1 sequence. The sofware recently apprear two status of in progress, please see the attached picture.
https://goo.gl/photos/6TEaWhCTcAdDrL6u8
Thank you guys so much for your help.
Go to that datafile location in Windows explorer. You will find it has an extra file that your other datafiles don't have (acquiring.txt i believe?) Once you remove that, in progress should go away.
I did as your support and it was actually fixed。 But I still wonder why this extra file appeared, because I did the same actions with other location files (creating sequence, choose data location,run sequence)。Others appear normal, but this one is quite different.
Thank you so much for your support me!
Users browsing this forum: Google [Bot] and 15 guests
