LC/MS topic
Just curious what do your think about the most challenging/most difficult part facing the LC/MS analysis? How do you usually deal with it? Thanks.
emily lee
Depends on what you are doing...
If it is analyses from a biological matrix, I would think that ion-suppresion is the general problem.
Uwe, Thanks for your answer. What do you do to minimize the ion suppression effect? What else beside ion suppression? Thanks so much.
emily lee
To reduce ion suppression stemming from a complex matrix such as biofluids, you need to reduce the complexity of the sample with solid sample clean-up techniques such as SPE and high-quality chromatographic separations.
You can test for ion-suppression issues by doing post--column infusion of the analyte(s).
In total there are 23 users online :: 0 registered, 0 hidden and 23 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 23 guests
