mV settings in electrchemical detection system.
Can anyone tell me how to select mV settings for electrochemical detection? I'm working on a methyl transferase with a C18 column, isocratic system. Mobile phase is phosphate-acetonitrile-THF at pH6.2. Samples are patient EDTA blood.
What, exactly, are you trying to detect? And what, exactly, detector are you using (manufacturer, and model number)?
The mV setting (working potential) defines your detector selectivity. An optimized setting may discriminate interfering peaks.
The working potential depends on the component to be analyzed.
Dr. Markus Laeubli
Manager Marketing Support IC
(retired)
Metrohm AG
9101 Herisau
Switzerland
Users browsing this forum: Google [Bot] and 1 guest
