Splitting GC-MS column
Posted: Tue Aug 29, 2006 1:55 pm
Dear Spectroscopists:
I have a HP5972-MS (with a 5890 oven) and am looking to separate out both heavy hydrocarbons and permanent gases for analysis in the MS. Some samples would be predominately composed of permanent gases (CO, CO2, N2) while others would contain heavy liquid hydrocarbons (C5-C20). Right now I am using a 30m RTX column (0.25mm, Restek) and am considering splitting the flow to a 30m Qplot (or equivalent column effective at separating permanent gases, particularly nitrogen and CO). The two columns would join back together at a Y-splitter and then enter the transfer line through a short guard column (about 5m). What are the ramifications of doing this? Obviously, a gas mixture would elute out pretty fast on the RTX column producing unresolved peaks (at less than 1 minute, perhaps). Does it stand to reason that there would be a significant portion going through the Qplot that would allow for sufficient separation? How would this play out?
Rich
Rich
