Capillary GC-MS sensitivty
I am having trouble with sensitivity, it dropped to 40% when I turned off power and restarted again. RT is increased by 10 seconds. I have same temperature and settings and vacuum is same as before. I would appreciate if anyone can help me figure out the problem.
Thanks.
Suspect leak at the injector...if you use vespel ferrule, retight again
In total there are 15 users online :: 2 registered, 0 hidden and 13 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], Semrush [Bot] and 13 guests
