TraceGC TraceDSQ(MS) detector gain calibration failure
Posted: Tue Sep 26, 2006 10:56 am
Hi everybody!
I'm working with Trace GC Trace DSQ GC/MS. Now I have the following problem : when I want to do autotune one messege appear "cannot perform detector gain calibration" !!!
From the previous tune file detector gain voltage is 1095V, so it's not to high!
When I ran the diagnostic tests everything is OK!
Air/water spectrum is OK
I performed leak check (Column evaluation) - OK!
I suppose taht may be the reason is sumthing wrong in the connection between PC and the MS, but how to be shure???
