Liner Volume
Hi all,
Can someone advise me on where I can get information of the effective volume of a Agilent 5183-4711 Split liner ?
I am trying to ensure that I use the right solvent so that it prevents back flush.
Thanks.
It has an 870 μL internal volume. :)
The Agilent calculator should have a built-in list of liners, no?
Unless he is using an older version of Chemstation with the 5890. That list is very handy and I am glad they added it to the newer versions :) I can't remember if the volumes are listed in the online catalog or not, which would be a good idea too.
Thank You.
From James:
That is why we all used the H-P (pre-Agilent) free flow calculator; it had all the volumes of the H-P liners built into it. Sure saved a lot of catalog time!
Mark Krause
Laboratory Director
Krause Analytical
Austin, TX USA
From James:
Thanks James.
Im using LECO ChromaTOF software and could not find these information.
Will have to refer to the catalog.
Users browsing this forum: Bing [Bot] and 11 guests
