EZchrome-Creating Calibration curve
I am trying to create a calibration curve for one analyte at a number of different
concentrations level.
I managed only analyze one injection every time and I receive each time only
one point instead of all seven injection in different concentration level.
Can you please send me the right proc ? Which parameters are critical to
create the cure?
Thanks!
in order to make a calibration curve you need to enter the concentrations in the compound table of the methods under the Levels. Each level its unique concentration. For 7 levels you fill out all 7. You can go up to 99 levels if you like to calibrate :).
Then in the sequence you tell which level corresponds to which calibration run and tada the method is calibrated when you reprocess.
Freek Varossieau
OpenLab CDS 2 specialist
BeyondOpenLab
beyondopenlab@gmail.com
+5977114721
Users browsing this forum: Ahrefs [Bot] and 8 guests
