ghost peaks in first blank, but not second
Posted: Mon Jul 31, 2017 8:05 am
Hi!
We are having a problem with distubing peaks in our chromatograms. We know its detergent and PEG, but what i think is weird, is that when im running tests i get a big disturbing peak at the first two or so runs, but the rest are fine.. even when im running the same injection, the same mobil face, and the same time and gradient.
Im also cleaning the system befor the run, and using the same the day after, but still get it in the first two or three chromatograms.. and running it on the mobilphase for about 30-40 minutes befor starting the run..
Mobilphase A: 16/84 ACN/Phosphate buffer
Mobilephase B: 70/30 ACN/PB
Only running Mobilphase as a test:
1: Mobilphase - inject control (big top)
2: Mobilphase - inject control (big top)
3: Mobilphase - inject control (top)
4: Mobilphase - inject control (small top)
5: Mobilphase - inject control
6: Mobilphase - inject control
And then im doing the same thing the day after on the same system, not cleaning it, only puring with mobilphase, and starting it with mobilphase befor the run.. and i still get the same results..
Im trying to upload pictures, but it wont work..
(Agilent 1100)
(Agilent 1100)
