IC columns and mobile phase compatibility
I´m looking for some information about mobile phase compatibility for IC anion columns, I have found that some silica based IC columns are not compatibles with Methanol or Acetonitrile (Vydac or Dionex for example) while others (alltech) can run up to 100% organic.
Is this due to silica modifications?
regards
K4
I doubt that the Dionex IC columns are silica based. Solvent compatibility depends on how the ion-exchanger groups are attached to the core particle. These groups can be attached covalently (e.g.Hamilton PRP-X100) or a ion-exchange latex is attached to a sulfonated core particle through electrostatic interaction (most Dionex columns).
It is possible to strip the latex from the substrate. This is not possible with covalently attached ion-exchange groups.
Always refer to the column manual for solvent compatibilty information.
Robert Haefele
thanks Robert,
You are rigth Dionex is not based on silica,
thanks for the information on Hamilton PRP
K4
In total there are 9 users online :: 4 registered, 0 hidden and 5 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot], Google [Bot], Semrush [Bot] and 5 guests
