Would this custom field work in a report?
I run a related substances method and have Two CF's for calculating Percentage Impurities. 1. Percent_Impurity and 2. Percent_Impurity_GTE0.1%.
If I split my report method into 2 tables- KNOWN and UNKNOWN Impurities, will the second custom field still only Sum the Percent Impurities GTE 0.1% for Known and Unknown or will it sum ALL of the impurities GTE 0.1%? I have the tables filtered by Known and Unknown Peaks so I presume this will be enough?
Any thoughts?
hi ,
If peak type in source selection : Known and Unknowns
table filter should be enough but worth checking
In total there are 23 users online :: 0 registered, 0 hidden and 23 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 23 guests
