Accuracy when preparing buffer solution
Posted: Sun Sep 03, 2017 9:18 am
A debate started yesterday at work - does the buffer mass/composition need to be exact or within a certain percentage (we argued 5-10%).
IMO, the molar concentration wouldn't change that much (0.01% for 1.2 g of NaH2PO4 AND 0.0092 for 1.1g) and the adjusted pH would be the same in both cases.
What are your experiences when preparing buffers? Do you weight the exact amount, water volume and pH? Or do you have +/- tolerance for buffer mass and pH and/or use measuring cylinders instead of volumetric flasks ...
Or does it depends on the robustness of a particular method?
