Amoxycillin and Clavulanic Acid Tablets USP
Dear Members,
Does anyone have experience to perform USP determination method for Amoxycillin and Clavulanic Acid Tablets? We found trouble when trying to prepare sample solution:
Dissolve not fewer than 10 Tablets, accurately counted, in water with the aid of mechanical stirring, transfer to a suitable volumetric flask, dilute with water to volume, and mix. Filter a portion of this solution, discarding the first 10 mL of the filtrate. Dilute an accurately measured volume of the filtrate quantitatively and stepwise with water to obtain a solution containing about 0.5 mg of amoxicillin per mL. Use this Assay preparation within 1 hour.
Amoxycillin is slightly soluble in water and in methanol. Clavulanate Potassium is moisture-sensitive, freely soluble in water, but stability in aqueous solution is not good, optimum stability at a pH of 6.0 to 6.3; soluble in methanol, with decomposition. So, we could not add any organic solvent to increase amoxycillin solubility.
Should we use higher capacity of volumetric flask (2 - 5 L) to follow the procedure?
How many replication should be perform? Within 1 hour we only got 2 run of analysis.
Siswanto
Yes. Since the "suitable volumetric flask" is not specified, you get to determine what that is.
Mark Tracy
Senior Chemist
Dionex Corp.
Users browsing this forum: Bing [Bot], Google [Bot] and 4 guests
