precolumn frit- hplc
Is it necesary to have a frit in inlet end fitting of precolumn (FOR SOLVENT) which is between pump and injector? :(
(precolumn is PE scavenger cartridge column C-18-10 um)
I am quite new in hplc, so i need some help.
Thanks [/code]
btw, is there a good internet site with hplc basics, columns, frits- technical support, not application
Vanja,
The frit serves two purposes: it is a filter and it holds the material in the column. You may not need the frit to be a filter but you will need it to keep the packing in place.
As to a good source of information for HPLC, well just check the postings in this forum, especially those for the Student section. Also, don't forget to look up (at the top of the forum page); check out the 'FAQ' link at the top.
Dan
Vanja,
Dan has a good suggestion to check out the archive of this site as well as the great sponsors of the site. In addition, here are some links to some other sites with good information on HPLC.
http://kerouac.pharm.uky.edu/asrg/hplc/hplcmytry.html
http://hplc.chem.shu.edu/HPLC/index.html
http://www.dq.fct.unl.pt/qof/hplcts1.html
http://www.chromatography.com/
http://www.uga.edu/srel/AACES/GCtutorial/page1.html
http://www.forumsci.co.il/HPLC/program.html
http://www.lcresources.com/resources/TS ... ingWiz.htm
Disclaimer: This list is not complete and does not imply personal bias on my part, yada yada yada ......
I hope this helps.
Users browsing this forum: Bing [Bot], Semrush [Bot] and 3 guests
