Can you use a Named Group in an intersample calculation?
Posted: Wed Oct 04, 2017 3:54 pm
I have 2 peaks eluting close together that I named(Peak A and Peak B-Named as "AB"). I need the average area of "AB" in 2 injections with the same label and that Custom Field works fine but when I multiply it against the Sampleweight of an unknown injection labelled S Sampleweight it gives me a wrong answer. So what I want to do is:
(Average_Area_of_AB * S.1.(Sampleweight) (Peak, Real, Calculated, All Peaks, All Samples)
Any ideas?
Any ideas?
