alfa bromo-2-chlorophenyl acetonitrile -hplc/gc method
Please give suggestion for the method development by hplc and gc
GC Use a Supelcowax 10 capillary. Avoid using higher temperatures for injection and column as you can debrominate the molecule easily. Other option would be a Equity 1701 capillary.
Use toluene or acetonitrile as a dissolution solvent.
LC A simple C8 RPLC column, or an Ascentis Phenyl LC column where you can use normal or reverse phase mode might be a good starting point.
Rodney George
Senior Research and Development Scientist
Gas Separations Research
Supelco
595 North Harrison Road
Bellefonte, PA 16823
814-359-5737 voice
814-359-5459 fax
rgeorge@sial.com
In total there are 9 users online :: 3 registered, 0 hidden and 6 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot], Semrush [Bot] and 6 guests
