Need a familiarization guide for ChemStation B.04.03 [16]
As per the subject line said, I'm looking for a guide to method setup and calibration curve creation.
I was previously sent a document by Agilent, but that was meant for GC, so most of the method setup does not applied to me, I also found another manual online but it is for a slightly older version that does not work for me either.
Hope someone can assist me with this.
See the attached 2 pictures for the software: https://imgur.com/a/kebpYtj
Thank you.
Except for the column heading "Instrument", there is no real difference between the GC and the HPLC software. So method setup and calibration curve creation would be essentially identical.
Users browsing this forum: Google [Bot], Semrush [Bot] and 5 guests
